Ok, So I Lied.....
#21
...on a side note on my way to work this morning in the back window of a Subaru wagon diven by a 45ish year old guy said..."OBAMA SUCKS"
I laughed so hard. It was a plain white bumper sticker with black lettering lol. There was no other sickers of any sort on the car, which made it that more random and funny.
#27
Lol hey whatever works
Hoss... i run the msd digital window switch, no fpss( tho its a good idea and i should), and a microswitch. I had the zex tps switch...it worked great for a while...i took it off my car and put it back on a few months later and it never worked again...when it was working it was awesome...but it was dissapointing that it decided to stop working...
None the less, summit will have all 3 switches( tps or micro, window, and fpss)
Or check out harris speed works( i cant remember their site off the top of my head) they make a nice all in 1(minus fpss) piece.
And yes i recommend running all three. The wiring will prolly get complicated with all of them, but ill gladly help you draw a diagram up...as long as u wire everything correctly itll work like a top
#28
So, just so I understand here...
The FPSS is to prevent the system from injecting Nitrous if the fuel pressure dips below a preset value(like 35psi)
The window switch is an enable/disable for preset rpm range.
The TPS switch is to make sure the engine is at WOT, otherwise it won't feed the Nitrous.
Does this all seem right?
Do nitrous systems come with a module that has sets of contacts so that all you have to do is wire the switches to it and go, or do you supply your own relay's?
I know NOTHING about Nitrous systems lol
#30
I dunno, i just dont like the idea of having the gauges out in the open like that. I dont like the fact that I have my wideband gauge ontop of my steering column either. The speed of sound pod looks a lot better than your average autometer stuff tho
