I am in the process of installing a K&N intake on my 02 GT. Just curious, what is the reason for disconnecting the battery cable before doing the swap? The instruction sheet requires that.
Yep. Keep Alive Memory, as silly as it sounds is what needs reset. Things will not run as smoothly for you if you do not disconnect the battery. It's not going to be a catastrophy or anything, but just do it.
