Installing Mac LT's?
Old Jul 28, 2010 | 05:36 AM
uberstang1's Avatar
uberstang1
Chupacabra
I had a bitch of a time putting on the LTs on my 4v this winter. Im not sure about a 2v but I'm pretty sure it would be next to impossible to install the LTs on a 4v without dropping the k-member. I purcharged and aftermarket K member kit so I was doing it all anyway. But with the 4v i had the motor jacked up as far as i could and i couldnt access any of the bolts from the engine bay because the bellhousing bottomed out on the chasis far before i could get hands and or a wrench down far enough due to the DOHC heads. I had to use an engine support fender bar and actually LOWER the motor far enough to gain access thought the wheel wells, and due to BBKs rediculous construction of wrapping primary tubes over the g*d damn flange holes it took me about 4 hours to get the headers on AFTER i had the k member out. ( I had to take a header off twice after finding out the hardware certain holes didnt have enough clearence from the primarys to get a stage 8 bolt in and needed factory studs re-used.)
Old Jul 28, 2010 | 07:59 AM
PurpleIcedGT's Avatar
PurpleIcedGT
I really hope to God that my MAC longtube install doesn't take me THAT long...
Old Jul 28, 2010 | 09:22 AM
smitty2919's Avatar
smitty2919
I did a LT header swap on my brothers 99 Dakota R/T....10am to 10pm with a lift and all air tools. One of those things that if you do it again it would take half the time.
Old Jul 28, 2010 | 09:31 AM
kolb02's Avatar
kolb02
So does my buddy need a tune with the longtubes and an off road H pipe?
Old Jul 28, 2010 | 09:34 AM
code3GT's Avatar
code3GT
Mustang Nazi
Nope. But also depends on how detailed of a record he wants for each specific bolt on. That would mean using the same dyno and operator, weather conditions, etc each and every time he goes to the dyno.
Old Jul 28, 2010 | 09:35 AM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
No he doesn't
Old Jul 28, 2010 | 09:39 AM
kolb02's Avatar
kolb02
So it won't throw check engine light when we remove the cats and do the off road H-pipe?
Old Jul 28, 2010 | 09:40 AM
code3GT's Avatar
code3GT
Mustang Nazi
MIL eliminators.
Old Jul 28, 2010 | 09:54 AM
kolb02's Avatar
kolb02
Cool I will do those. I have some that I bought for my 96 cobra a while back, will that work on this 2003 gt?
Old Jul 28, 2010 | 04:11 PM
WannaBeGearHead
Go Texas!!!
If he has a tuner he can turn them off that way.
mtgldr
Feb 3, 2024 09:00 PM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
