Rear end FULL after only 2 qts!!
Old Aug 19, 2010 | 04:26 PM
stallion11030's Avatar
stallion11030
Default Rear end FULL after only 2 qts!!
so i decided to change the rear end fluid today and got to the filling part and the oil began coming out after a 4oz bottle of f/m and 2 qts of oil..... WTF could be going on???
Old Aug 19, 2010 | 04:51 PM
Timspony's Avatar
Timspony
SVT Section Moderator
...That sounds about correct!
Old Aug 19, 2010 | 04:57 PM
stallion11030
..... i was told it would take about 3.25 qts of gear oil???
Old Aug 19, 2010 | 05:11 PM
tbirdscwd's Avatar
tbirdscwd
Mine only took 2 qts. But if you are worried, cap it at 2 qts and go drive it around for a few min, then recheck the level. Make sure you are on level ground when you are checking the fluid level.
Old Aug 19, 2010 | 05:31 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
It's 4.25 pints of oil, or 2 quarts + 4 ounces (1/4 pint) of friction modifier--if bone dry, on a refill it's a bit less as you found.
The 7.5" axle on the 6-banger takes 3.25 pints...
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
