sock & strut problem
Old Aug 21, 2010 | 04:13 PM
01redstang's Avatar
01redstang
Default sock & strut problem
wassup guys? I Just finished installing my new Bilstein Shocks & Struts on my 01 GT. The installation was not bad at all. just one problem, I gained about a 1/4 inch of height out back & 1/2 inch up front... WTF is this normal? I got 2 inch lowering springs on all 4 corners.. the car had an even stance before i started. now it sits higher up front. I'm 100% positive I did the install correctly.. I test drove the car it drives much nicer now. I just don't get the odd stance now.
Old Aug 21, 2010 | 04:57 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
The Bilsteins have quite a bit more compression pre-load, you may have noticed this when you had to compress them during installation--this higher pre-load raises the car's stance just as would a higher rate spring.
They will settle in a some, but likely always ride a bit higher.
Old Aug 21, 2010 | 05:10 PM
hpwrestler220's Avatar
hpwrestler220
What cliff said ^^
This isn't the first time i've heard this with the bilsteins.. It's common.
Old Aug 21, 2010 | 05:27 PM
teej281's Avatar
teej281
4.6L Section Moderator
It happened to me with my stock 03 cobra bilsteins when I put them on...just gotta remove some isos to even it out. lol or go coilovers...like me
Old Aug 26, 2010 | 03:22 PM
01redstang's Avatar
01redstang
thank you guys for the info.. i guess i have to remove the isos up front & see what happens. Looks like I'm going to have to get my camber re-adjusted up front too. will new spring help? I was thinking the H&R Super Sport Springs..
Old Aug 26, 2010 | 03:50 PM
MustangMan00's Avatar
MustangMan00
a lot of people go with shocks made for fox body cars because they bolt up the same but are meant for a shorter travel distance
Old Aug 26, 2010 | 04:47 PM
teej281's Avatar
teej281
That has nothing to do with the op's issue.
Old Aug 26, 2010 | 04:49 PM
teej281's Avatar
teej281
If you're gonna do that, just get front coilovers. That's my personal opinion.
67STANGX2
Sep 24, 2015 12:29 PM
warwickbass
Sep 20, 2015 04:51 PM
GentleBen
Sep 11, 2015 05:34 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
