Horrible Gas Mileage From My 2000 GT
I honestly just drive regular with the speed limit i dont floor it or gas it unnecessarily. And no rush hour traffic, there arent any check engine lights, oil and oil filter change every 3 thousand miles, air filter is clean, spark plugs are good, brakes are good i mean i dont know whats causing it to eat so much gas.
Change the fuel filter. When I changed mine, I picked up 3 mpg roughly and mine wasnt even clogged. I think that may end up being your problem, and possibly your cats. Check the fuel filter first. Does it feel sluggish at all?
How many miles on it? As O2 sensors age their output drops, the lower voltage makes the PCM think the engine is running lean and it compensates by making the mix richer--this can and does happen with no DTCs being thrown.
On cars that see a lot of highway cruising O2 sensors can last 100k+ miles (mine are headed for 105k and are working fine), however on cars that are used mostly around town and routine short trips (only 3 to 5 miles) they can be shot in 50k miles.
