4.6 to a 5.4, is there a sticky??
Old Sep 21, 2010 | 05:39 PM
98-GT's Avatar
98-GT
Default 4.6 to a 5.4, is there a sticky??
What is entailed in a.6 to a 5.4 swap? Is there a write-up somewhere? There is no replacement for displacement!
Old Sep 21, 2010 | 05:58 PM
PurpleIcedGT's Avatar
PurpleIcedGT
depends on what your goals for the car are man, a 5.4 V8 swap will probably only yield 275-290 horse....Are you look for 350? 400? 600? There are far more cost efficient ways to achieve a higher horsepower goal....
Old Sep 21, 2010 | 06:02 PM
MU71L4710N's Avatar
MU71L4710N
moddedmustangs.com and search for threads started by a guy named 330cubegt. its a very good writeup for swapping in a 2v 5.4L.
HOWEVER, you need to know, that doing the 5.4 2v swap is going to cost you quite a bit of money for very little power gain over a PI 4.6L.
that motor is only rated for 260hp and 350tq stock (compared to 260/300 on a PI gt). unless your doing a 3 or 4v dont waste your money IMO. the only reason i would ever do this swap is if i found the motor dirt cheap in running condition, or my motor was blown.
if your motor is still running strong, a cheaper and easier option would be just to PI swap your car. the only difference at that point is less than 50tq since your compression will be higher than a standard PI gt. you can buy everything you need for a PI swap for a few hundred bucks. the 5.4 motor, manifold, and whatever else you end up buying you can spend 2000$ or more.
Old Sep 21, 2010 | 09:26 PM
amoosenamedhank's Avatar
amoosenamedhank
Or you could just buy my mustang which already has a 5.4 2v swapped into it... fantastic, just stop on by with the money and she's all yours!
Old Sep 21, 2010 | 10:09 PM
JC316's Avatar
JC316
You get added torque, but you lose any chance of cheap intakes and exhaust. Plus your hood has to be right. With the HPS intake, you can see a serious increase in power over that 260/350. Everyone I have ever talked to that did the 5.4L swap didn't regret it. Moddedmustangs.com is the place, 330cubegt has a writeup and sharkbait just did the swap.
Old Sep 21, 2010 | 10:43 PM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
A guy over at Modular Ford swapped in a STOCK '04 Navi motor with Cobra headers and I believe the Boss intake. Guy made like ~325/360. Not bad for a stock Navi motor.
Edit: Exact numbers were 325/370 with the Aussie Boss intake
May 9, 2024 05:51 AM
mdj89
Oct 26, 2015 11:53 AM
mdj89
Sep 23, 2015 08:49 AM
rksnow1
Sep 14, 2015 08:46 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
