JBA Header install
Old Oct 4, 2010 | 11:11 AM
rockarmymedic's Avatar
rockarmymedic
Default JBA Header install
Im getting ready to put a set of short JBA headers that a friend gace me on my 96 GT. Can anyone tell me the easiest way (IE not scrapping the whole damn car) way to put them on? Im thinking about dropping the K member and engine out the bottom and doing it that way. Im station here at Ft Polk LA and need something to do this weekend as it is as exciting as watching a camaro rust here on the weekends.
Old Oct 4, 2010 | 11:23 AM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
Dropping the K would you give you plenty of clearance so you don't scrap the headers.
Old Oct 4, 2010 | 11:33 AM
kugzgt's Avatar
kugzgt
^word. if i did it over again i would def drop the k member
Old Oct 4, 2010 | 05:29 PM
changolocs85's Avatar
changolocs85
i dropped the kmember when i did my headers a couple years ago. its pretty easy if i remember right. what unit you in? im at polk too and if im not too busy i might be able to help. what color is your stang?
Old Oct 4, 2010 | 08:59 PM
rockarmymedic
Im the 162 BDE Medical Supply NCOIC on N Fort. What about you? Mine is hunter green in some spots and flaking clear coar in other spots. After I get it done Im gonna flat black it.
Old Oct 4, 2010 | 10:04 PM
stangalator's Avatar
stangalator
+1 on k-member drop. Make sure to line the k-member back up correctly, it can move a bit and not be straight.
Old Oct 4, 2010 | 11:50 PM
changolocs85
i think ive seen it. i drive the silver one thats completely gutted, im in 4/10 MTN so i won't be here much longer
Old Oct 5, 2010 | 06:02 AM
uberstang1's Avatar
uberstang1
Chupacabra
I've done longtubes twice this year, the easiest and fastest way is to drop the K-member.
Old Oct 5, 2010 | 10:02 AM
rockarmymedic
How would you all recommend hanging the engine. Im thinking a steel beam on the strut towers with either a strap down and undert eh engine and back up or move the steel fwd and use a bolt on the front of each head.
Old Oct 5, 2010 | 10:09 AM
WannaBeGearHead
Go Texas!!!
Put a jack underneath the oil pan with a wood block in between.
When I "dropped" my K member all I did was lower it maybe 4-6". That gave me enough header bolt clearance and made it easy to get back in place.
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
