new to mustangforums
thx for the info and yes it has the lage intercooler from kb. i called kb and they told me that at the rwhp it will be 405 hp and 427 ftlbs with this set up, but they did say it might be higher or lower on what dyno i take it to but not by much either way. he told me that they stand behind there numbers. welllllll i guess it time to look for a bottom end before my goes
You will need bigger injectors for 10-11 PSI, especially 14 PSI. At 14 PSI you will be at 460-480RWHP and you will need a forged bottom end to handle that power anyways. You will also need an upgraded fuel pump to run 10-14 PSI. You may be able to get away with 36LB injectors and stock pump at 10 PSI but you're flirting with disaster. The KB is a ****ing blast words cant do it justice.
09-09-2015 10:30 AM
09-08-2015 05:21 PM
