Lightning MAF
Old Oct 19, 2010 | 09:34 PM
0949er's Avatar
0949er
haha I hope you just inherited $25k because a worth-while low mine GT + turbo + supporting mods will cost you about that much.
however, you can get a cheap GT and cheap stuff and do it a lot cheaper then that im sure.
Old Oct 19, 2010 | 09:38 PM
Fuel's Avatar
Fuel
what other supporting mods am i forgetting if i buy the on3 kit with all of the upgrades
Old Oct 19, 2010 | 09:39 PM
Fuel's Avatar
Fuel
i see that you have cams, do those work on the stock engine without PTV problems
Old Oct 19, 2010 | 09:56 PM
MU71L4710N's Avatar
MU71L4710N
well your wanting 600hp.
your going to want a beefier tranny, rear end, you need a built short block, some heads and cams, you will need to do your suspension in order to plant any of that power to the ground, etc...
hes not joking when he says 25 grand.
Old Oct 19, 2010 | 09:59 PM
Fuel's Avatar
Fuel
For this year I am going to stay with about 400 hp so what other supporting mods do I need for that?
I have already thought about the tranny, clutch, rearend, suspension, etc along with the shortblock for later.
Old Oct 19, 2010 | 10:01 PM
0949er's Avatar
0949er
you gotta just ask about the actual cam you pick to make sure. My cams do not have any PTV clearance issues, but people will say that I am lucky (because I have a pretty aggressive stage 2 cam). From what I understand you can simply degree the cam a tad to make extra clearance.
You NEED cams if you are expecting to put out any power with your motor. You will not be able to do it with the stock ones.
For example, I am easily pushing over 400 rwhp on only 7.5 lbs of boost (at peak!!), whereas another mustang w/ out cams will struggle hitting 400 with 10+ lbs of boost (which is almost almost 2x times the pressure)
No, I was not kidding about 25k lol... actually.. I think that's quite generous if you want it done right and built a motor as well. (and dont forget a tune at a GOOD shop, with QUALITY work)
Old Oct 19, 2010 | 10:04 PM
0949er's Avatar
0949er
its a lot man. That alone is about $3-4k w/out install.
You will have a hard time hitting 400 w/ out cams and few mods. You will pretty much need full bolt ons + 10 lbs of boost to hit 400
or possibly a little less, I am not as familiar with turbos power output
Old Oct 19, 2010 | 10:09 PM
Fuel's Avatar
Fuel
i am not doubting the 25k. Also, the turbo kit is about 3500 and i will be doing all of the install myself. I talked to the guy that will be tuning the car the other day(he has tuned a 4v car with an 88mm single) and he said that he has tuned a few cars with this exact kit and said that it won't have any trouble hitting that kind of power. I will also be adding a meth kit since I can't get gas any better than 89oct withing about 45 miles.
Old Oct 19, 2010 | 10:34 PM
MU71L4710N's Avatar
MU71L4710N
you dont need 10lbs with a turbo, its more like 6 i think.
jwog666
Dec 27, 2021 08:09 PM
piotrek53
Oct 13, 2015 06:54 PM
mltdwn12
Sep 23, 2015 08:54 AM
Sep 18, 2015 06:49 PM
Sep 18, 2015 12:25 PM
