Which to get first? Tuner or 70mm TB?
#21
Do you wish to tune it yourself, or pay to have it done?
The other change I would recommend, based on my recent experience, is to upgrade the fuel injectors to the FRPP 24lb/h EV6 units. I have not been up on the rollers since installing these, however the butt dyno and my G-Tech both report a good kick in the pants at WOT and in the 4500-6000 rpm range.
You will need to change the injector low and high slopes, breakpoint, and minimum pulse width settings in the tune to use these...
#23
Another issue is that you really should run at least one full tank (preferably two) of 93 octane fuel through the engine before switching from a tune configured for 87 octane, to one optimised for 93.
#24
Didnt read the thread, but ill say my piece.
If your gonna stay with a bolt on GT for a while, skip the intake mods entirely (IMO). For the money you will spend on a CAI and a tb/plenum(around 400-600 for top of the line parts) your going to get minimal actual RWHP out of it.
The real gains for a bolt on car are the exhaust, and a tune. Long tube headers, o/r x pipe and a straight through muffler catback and a tune (and if your really getting antsy to spend money put in a K&N filter) will net you somewhere around 30 RWHP. A full exhaust was the only mod I put on that I could actually feel. When I nailed the tune you could definitely tell that something was done to the car.
I really dont think you need to touch the intake side until you do some head work on the car.
#25
I agree 110% about the CAI, however the stock upper plenum is a weak point.
Replacing it with any of the after market units and a 70mm TB can be done for $200 or so, and with an optimised tune will provide noticeable and worthwhile gains in the upper mid-range and higher rpms.
That said, without an optimised tune (or for those that never rev the engine beyond 3500 rpm) there will be little if any benefit.
#26
#27
Fuel economy does sometimes suffer after an engine has been modified/tuned to achieve increased power, however this is almost always because the increased power has a way of making people's right foot heavier...
#28
The comment about running out the tank at least once, depending upon how low you run your car between fill-ups, is a good idea before switching tunes. If you mix 93 oct with some 87 oct, you certainly will not have 93 oct going into the motor.
#29
You could have 93 street tune
93 Race tune
and
100 Octane Street Blaze Race tune.
Sine you want the SCT, with 3 options.
That 100 octane stuff ain't exactly cheap, but it's better than octane boosters.
#30
You'll have to get at least 8% better fuel mileage just to pay for the more expensive gasoline.
