Brand new clutch....slipping
Old 01-26-2011, 10:49 PM
mustanguy91
mustanguy91's Avatar
Another possibility is that your clutch fork could have broken... or the little bal that goes into the end of the fork where it engages. If it isnt lubed... it can mess up. It can be a lot of things. Did you get it installed at a shop or do it yourself? If it was a shop install, you should take it back. They should fix it with no charge beacuse something is messed up.
mustanguy91 is offline
Old 01-27-2011, 12:04 AM
teej281
4.6L Section Moderator
teej281's Avatar
I'm feeling a broken quadrant coming on. Lol pulling back on the clutch pedal, stock plastic quadrant, pop sound. Seems to be adding up. Nice chance for an upgrade!!!
teej281 is offline
Old 01-27-2011, 12:10 AM
everett
everett's Avatar
I don't have any nitrous runs on this clutch...and I got it installed in kelowna and drove it the 1400 kms home and put on maybe 3000 kms more before it went into storage...I will check it like you said. Thank you very much for the help gentlemen
everett is offline
Old 01-27-2011, 05:43 AM
uberstang1
Chupacabra
uberstang1's Avatar
Originally Posted by mustanguy91
Wait... you said you were installing nitrous? Its a brand new clutch? You didnt powershift, or go flying down the road did you? All clutches have a 500 mile break in period. Their just like gears. You have to drive completely normal and baby the car for 500 city/ highway miles. If thats not it than it could be your adjustable clutch cable. Take the shield off that covers your cable where it is connected to the tranny. Pull back the fork under the shield with a prybar and adjust away. Might have slipped or broken loose. If neither of those are the cause then odds are the pressure plat, clutch, or flywheel wasnt torqued down right.
+1 on the clutch break in period, -1000 on the gear break in, gears do not have a break in period.
uberstang1 is offline
Old 01-27-2011, 07:51 AM
everett
everett's Avatar
I got it done by Aamco in kelowna which is about 1400 kms away...I wonder if they have a nationwide warrantee
everett is offline
Old 01-27-2011, 09:50 AM
mustanguy91
Anytime. By the way let us know how it turns out and what the problem is. Im curious whats wrong with it. Thanks and good luck with it man.
Old 01-27-2011, 11:19 AM
everett
everett's Avatar
Thanks alot for the tips I am gonna get under the hood this weekend. I will update this thread once I get some answers. Thanks again guys
everett is offline
Old 01-27-2011, 11:41 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Look under the dash first
WhiteFoxGT is offline
Old 01-27-2011, 12:11 PM
teej281
teej281's Avatar
^That
teej281 is offline
Old 01-27-2011, 02:47 PM
everett
everett's Avatar
Doing it right now...what should I be looking for
everett is offline
Quick Reply: Brand new clutch....slipping
