Well, i came across a deal i could NOT pass up. Im getting a polished v2 s-trim, AFM powerpipe, 42lb ford racing injectors, 90mm LMAF, Bosch 340 pump, kennebell BAP, accufab 75mm plenum and tb, and the radiator hose for 2800$. This is going on a bonestock motor with longtubes, o/r h-pipe and blowmasters. PO said he was seeing 10lbs of boost max. Any HP guesses? blower isnt gonna go on till summer because for right now its my DD till i sell my fox in the summer and pick up a nice little 4-banger.
This is non intercooled, and no meth added i take it? If so i'm i'm gonna say 370-380 rwhp at most because your tuner won't be able to get too aggressive with it.
I am running the same kind of set up, but 39# injectors and a GT supercar pump. I am at 8# of boost and am only at 340rwhp. They had to retard the timing due to my high AIT's. If you put the intercooler on they can add more timing and get you more power.
