Methanol on NA Car
Methanol on NA Car
I have been looking into putting a Methanol kit on my car and am curious how many of you have actually used methanol on a NA car and what your experience with it is. I realize that the gains power wise will be nothing like that of a force induction car. I am really after the mileage benifits more than power benifits. My current engine mods include LT headers, catless h pipe and 2 1/2 catback, CAI, UDP, 24# injectors, Trickflow intake and TB, Accel coilpacks and wires, NGK G-Power Plugs, Custom Tunes by VMP tuning. This is my DD so I am looking for ways to get better mileage out of it without back off of my current power output. Thanks in advance for input.
I've discussed this before and unless you're running lots of compression or boost, you don't really get the benefit of it. I mean you might get some mpg out of it, but enough to benefit buying the kit, then filling it with methanol over and over again, it's kinda pointless. Only application for meth in my opinion is performance.
I see the idea behind this kit, as far as using it for MPG anyways. Instead of using more gas when you put the throttle down, it uses a mix of meth to maintain the proper a/f ratio for the situation, so you dont use as much fuel. But the idea of using an alcohol-type fuel to do this is not smart, as alcohol based fuels are oxygenated and use more fuel to maintain the correct a/f ratio. Plus with windsheild washer fluid(methanol based) is like $3/gal anyways. You might try though using E85 in this type of kit to see how that might work. Just an idea.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
