MHS vs CMS cams?
i did a couple comparisons just looking at some of their turbo cams, MHS seems more conservative vs CMS. both AFAIK use bullet racing cams as their supplier, so quality should be the same, just different grind numbers.
MHS through and through.
Call Nick Mckinney (MHS) and ask him whats up.
Speaking of Pi swapped Sn95s....check out KugzGT's car. MHS 2's, PI heads, longtubes, 3.55s, and traps 106 in the 1/4 with a meatball driver and horrid tires. Put down 293/292 to the wheels. Imagine his times with 4.10s, a tire, and a driver......
Most people think that anything over 3000 is too high for a street car. I have no problems with my 3800 stall and it's very streetable. Honestly, doesn't feel much difference then driving a stock converter.
You shouldn't have any problem.....I wouldn't be surprised if you hit a 12.5. I love those cams. You can definitely tell Kugzys car has more in it too.
BTW did you run yours as well? If so what did you get?
