What's the cheapest way to ADD 100 HP to a stock stang?
Old Apr 30, 2011 | 10:16 AM
  #51
Sxynerd's Avatar
Sxynerd
Originally Posted by Tommy079
My brother in law just bought a R/T charger that's rated at 370 HP stock. My mustang is rated at 260.
Without using NOS what's the cheapest way I can add 100+ HP to my stock car.
I'm already looking into some 4.30 gears and a tuner. And I'm going to put on a K&N air filter and a SSS Terminator Catback system.
Other than that I don't know what I want/need to do? I'm pretty sure a super charger would do it, but the way I understand it is all that get's pretty expensive.
I don't want to do a half A$$ cheapy job, but I want to get the best bang for my buck.
So what do you all think?
You better sure have some sticky tires and great suspension if you want to add 100hp with Nitrous while having 4.30's.
Your BIL's charger is an over weight hunk of S* with stock gears and not in anyway a good comparison between cars. 4.30's and a good tires & suspension setup even at your power level will give him hell in the 1/8th. Work with what you've got add power AFTER you've done everything else.
-So sayith the Lord.
Old Apr 30, 2011 | 04:39 PM
  #52
Bman2000's Avatar
Bman2000
then people are misunderstanding what im saying...because a turbo 5 speed is way different than a factory, or full bolt on mustang. all i was saying is full bolt ons, gears aren't worth it, and im not sure someone could show me that they where unless they put big and littles on their car and left the line with a 1.79 or less 60` which almost means you need suspension as well. thats all i was saying. Hell this may not be accurate for other years, but for 99-04.....not worth it until you can trap over 103-105
Old Apr 30, 2011 | 06:20 PM
  #53
TRUEBLUE3934's Avatar
TRUEBLUE3934
Originally Posted by Bman2000
im not saying they dont have their place....but with your 3.27 your 3.73 and your 4.10 did you ever go to the track and actually do a real comparison? as opposed to your butt feel? and since i ran a 2.0 60` with street tires and 3.27s i dont think i was starting out in 7th. and for 9 people out of 10 id put money down that the majority does better at the strip with factory gears. just saying....... oh and autos are different than than stick which do you own? autos i agree gears are worth it...stick i put my foot down.
I did in fact say that I had raced my car with all of those gears. I have a 5speed car.
I would take any money you wish to bet on 9 of 10 people running faster with stock gears than shorter gears, it just isn't so.
The original question was what OP should do to improve his chances of beating the Charger. He currently has a stock GT which will NOT make enough power to smoke the tires under acceleration beyond first gear, unless you try to keep the tires spinning thru first and second gears.
I was running 2.00-2.06 60' times with 4.10 gears and very old 245 Gatorback tires. Short gears does not mean that you will automatically wind up spinning the tires like crazy. You just have to learn not to over power the grip you have available. The 4.10 gears WILL help your ET a lot on the back end of the run too.
Everyone has to decide where they want to invest their cash to gain the results they want, but I would strongly encourage anyone to install shorter gears as their first mod.
Old Apr 30, 2011 | 11:20 PM
  #54
Bman2000's Avatar
Bman2000
well i didnt have so much luck, and it coulda just been how much i changed in short a short time that made my car difficult to relearn. I ran my 2.0 60` times back to back with the 3.27s and trapped top of third...even taking the possibility of spinning out with the 4.10s or 3.90s like i have now(i dont spin much in first and dont spin second just have a hard time getting that 2.0 back). that extra shift still costs time, and with a 2.0 60` on street tires the initial gain you get from gears is kinda out the window.
i mean unless i misunderstand a little, the basic idea is torque multiplication in order to get the car out of the hole and into its power range faster and keep it in the power range? But with a factory car, most of you gain would come from the launch...and if my launches are equal....i personally doubt that the gears make up for the extra shift after the fact(in a factory mustang)...but its just my opinion.
I will say though, there is a reason the seriously fast cars run through the trap tapped out in their final gear. i know quite a few 10 and 11 second drivers and cars, and what they run. No one has to agree or listen. just my point of view.
i now have a light flywheel and a 6 speed and 3.90s and the combo of added weight from the tranny and the difficulty of launching with a light flywheel has pretty much kept me from matching my best...so far im over .5 a second off from my last best and im running DR so maybe im just grumpy. Id like to see some direct comparisions tho.
Old Dec 10, 2017 | 11:28 AM
  #55
Mustanger21's Avatar
Mustanger21
Originally Posted by SVTeeshirt
4.30s is to much gear for a car that revs to 5850.
4.10s are plenty.
amen to that! Especially if you are running nitrous. Start out with the wrong bang! Just from a burp!
Old Dec 10, 2017 | 04:25 PM
  #56
P51E's Avatar
P51E
With a 4.30 rear end, you’ll only have about 2.5 seconds in 1st before hitting redline, and will limit top end speed in 4th and 5th. The 4.10 is plenty fast. But, 4.30 (and 4.10) works with 6 speed T56, starting in 2nd gear instead of 1st.
2007CalSpec
Dec 13, 2020 11:42 AM
Roush05
Sep 10, 2015 12:23 PM
M3hunter
Sep 5, 2015 03:42 PM
TimeLord101
Sep 4, 2015 09:27 AM
Luke9222
Sep 4, 2015 06:46 AM
