What's the cheapest way to ADD 100 HP to a stock stang?
#21
Personally, I wouldn't get 4.30 gears, unless you love to shift. I would go with the 4.10's. You get off the line quick and even if you don't start from a stand still you'll still have enough torque to beat him. I would go with the supercharger or either a turbo IMO.
#22
#25
Well fortunately for dodge the two cars are in different classes. But even the challenger weighs a ton. Chrysler in general uses the same frame for the charger/challenger/300 to save money ( almost positive on this)
#28
I don't know how this helps, but it's good info.
#30
A lot of good comments on this question!
The Charger is NOT very quick in stock trim, so it won't take very much to out run him. 4.10 gears is a great start! Decent tires will help to get it moving from a stand still. A small shot on nitrous (50hp) would be more than enough to easily walk all over the Charger. You don't need the same amount of power since you have FAR LESS weight.
