CC Plates?? brand and can i do it myself adj..
so had my car at the shop up on the lift getting my new exhaust put on which i absolutly love with the stock mid. but anyways i noticed my front tires were starting to wear on the insides because of my new springs. so i am going to buy cc plates dont know which ones to buy prolly just the mmsports ones. but can i adjust the toe in and fix my alignment problem myself it drive straight and no wobbles just this toe problem. i took it to a shop right after i installed the springs and they didnt wanna do it because i needed a new inner tie rod. ok fine asked them how much and they said $320 and i said forget about it because the part was 15 and i could do it in less than an hr with my inner tie rod tool from otc.
if you can change an inner tie rod then you certainly have the ability to align yourself. The cc plates make it super easy todo yourself. I'd try it yourself and then go into a local shop (for me it was tires plus) for a free alignment check and print out once you think you got it. They'll let you know where its off (if any) and then if so go back and dial it in. No need to spend 50 bucks or whatever for a 15 minute alignment job.
Edit: after i lowered my car (put in springs) I aligned it myself and then took it to TIRES PLUS. They checked it & asked why i though something was off? I took em i just put in lowering springs. Well they told me i did heck of a job because (even gave me the print-out). Everything was w/in the right spec.
You can adjust the stock tie rods yourself to correct the toe problem. Buy some new CC plates and take your car to a shop for an alignment. They can adjust the stock tie rod ends. Don't let them tell you you need new ones. It's not a bad idea but not needed.
Unless the tie rod is totally screwed and bent you don't need to do it right away, but you may wanna replace it when you get a chance. As for doing the alignment yourself, you can give it a shot but like sonicx said I'd at least take it to a tire shop and have them do a free check, you don't wanna wear your tires out prematurely in order to save a few bucks on the alignment
If you have a bad inner tie rod thats probably what is causing your tire wear, fix the actually problem before throwing other parts in it. The shop is right theres no point in doing an alignment with a bad tie rod the tires are still gonna wear uneven. You may not even need CC plates either.
Does the tie rod have some actual play in it or were they just saying it needs to be replaced cause its old? uberstang is right if the tie rod is loose, all the alignment in the world wouldn't help it if the tie rod itself won't hold the length you set it to
