sct tuner - what now?
Old 05-25-2011, 08:25 PM
rsh0763
rsh0763's Avatar
Default sct tuner - what now?
I have to admit, with the tuners I purchased for my turbo diesel, it was simple, add power. With this sct deal, there is a bunch of stuff I can change. I have the open Hpipe, I have the flowmaster 40's. A CAI with Donaldson (amsoil) conical filter. Not much more, but I see all sorts of tuning options to pick.
4.10 gear set kit will be here next week. That, I know what to so with, but is there any special settings I should be using? Running 92 octane at the time, should I set the tuned for 93 or 91? What about WOT lean/rich?
I have access to a dyno, but not often.
Set the shift firmness at +15% between 1-2 at wot and on wet pavement, it almost sent me into a posi spinout.
rsh0763 is offline
Old 05-26-2011, 07:57 PM
badlx87
badlx87's Avatar
I have been wandering the same questions about setting the tune on my car. I just run what BAMA sent me, their the proffesionals lol. If I had more knowledge on tuning, I'd probably just do a custom tune on it. Do you not have 93 octane available near you?
badlx87 is offline
Old 05-27-2011, 10:17 AM
rsh0763
rsh0763's Avatar
I have (92) octane in this area and I have come to the conclusion that it isn't REALLY 92, I had the 91 octane setting on the SCT and it was pinging on hills that it normally just cruised up on 87.
My FRPP 4.10 install kit just showed up, time to get to work. The only real values I see in the tuner are the rev limiter, trac control disable, shift firmness and then WOT mix+ shift timing. I have been a gearhead for as long as I can remember, but I can never remember spark changing from 0-2000 to 2000-4000 RPM. To me, spark is spark and messing with it on an ECU controlled engine with no distributor is for the real pros.
rsh0763 is offline
baddog671
07-26-2016 01:20 PM
12bigredstang
09-24-2015 05:46 PM
03blackwidow
09-20-2015 02:36 PM
kmad61
Tuner Central
09-18-2015 05:02 PM
nboost
09-16-2015 05:35 AM
Quick Reply: sct tuner - what now?
