Drag wheels...kinda
Old Jul 18, 2011 | 11:58 AM
teej281's Avatar
teej281
4.6L Section Moderator
They fit fine. It's got a tread width of 9.5". And that's narrower than most 275's.
Old Jul 18, 2011 | 02:31 PM
01snake's Avatar
01snake
You can fit 15's on a IRS.....
Has been done many of times on modularfords
Old Jul 18, 2011 | 02:43 PM
Moonshine's Avatar
Moonshine
It just that one bolt that gets in the way right?
Old Jul 18, 2011 | 04:12 PM
BraMas's Avatar
BraMas
Yes with spacers and grinding. Just like my post says (sorry I left out the grinding part). I didn't realize we where going to debate the topic or I would have been more specific
Old Jul 19, 2011 | 06:10 PM
turbo232's Avatar
turbo232
Originally Posted by BraMas
because he traded for them. if he gets 15's he would have to run spacers in the rear. You can't even run 16's with an IRS
yeah you can...i have done it.
Old Jul 19, 2011 | 06:16 PM
teej281's Avatar
teej281
16's and IRS works perfectly fine.
Old Jul 19, 2011 | 07:20 PM
ctgreddy's Avatar
ctgreddy
i had those exact same tires on a 96-98 gt rim on my 95. they were ok, but the small sidewall and not wide enough rim did hurt. they fit on the wheel just fine but you'll be able to see that they aren't wide enough.
regaurdless of that, i cut 1.6 60's with them dumping the clutch at 5k in the '95. I had to run about 12psi in them and do one nasty burnout to get them to hook tho.
Old Jul 19, 2011 | 08:15 PM
KillJoy's Avatar
KillJoy
I don't see this going as planned..
Old Jul 19, 2011 | 08:31 PM
ctgreddy's Avatar
ctgreddy
one of the reasons slicks are safer is because the sidewall has more give in it isn't it? thats the way i always understood it. but when you're running a 26" tire on a 17" rim you're pretty much taking all the flexing sidewall out of it.
Old Jul 19, 2011 | 10:12 PM
BraMas's Avatar
BraMas
OK I give up I must have the ONLY 15 and 16 in mustang rims that will not work on an IRS. Ignore me because obviously I'm an idiot. I have personally had both 15 and 16 on my irs and they DID not fit.
