Drag wheels...kinda
Old Jul 19, 2011 | 10:28 PM
  #21
turbo232's Avatar
turbo232
Originally Posted by BraMas
OK I give up I must have the ONLY 15 and 16 in mustang rims that will not work on an IRS. Ignore me because obviously I'm an idiot. I have personally had both 15 and 16 on my irs and they DID not fit.
i know the 5 spoke 16 inch V6 wheels will work.
Old Jul 20, 2011 | 05:35 AM
  #22
uberstang1's Avatar
uberstang1
Chupacabra
Originally Posted by ctgreddy
one of the reasons slicks are safer is because the sidewall has more give in it isn't it? thats the way i always understood it. but when you're running a 26" tire on a 17" rim you're pretty much taking all the flexing sidewall out of it.
Theres information that supports this theory, but theres also alot of information that is against this theory.
Old Jul 20, 2011 | 09:16 PM
  #23
TRUEBLUE3934's Avatar
TRUEBLUE3934
Will a 15" wheel fit over the Cobra Brakes?
Old Jul 20, 2011 | 09:34 PM
  #24
turbo232's Avatar
turbo232
not the front ones.
Old Jul 20, 2011 | 09:38 PM
  #25
KillJoy's Avatar
KillJoy
Originally Posted by turbo232
not the front ones.
Won't fit the rears either, you need to grind away at the calipers for clearance.
You can get 15's to fit on the front with cobra brakes.. I had a set of 15x3.5's on my car. You just need a spacer.
Old Jul 20, 2011 | 10:55 PM
  #26
01snake's Avatar
01snake
Just put 15" pro stars over my cobra brakes.....
Front need 1" spacer, I used steedas had to get diffrent lug nuts because steeda is a dumbass
Rears had to grind banjo bolt and a littler off the top edge of the caliper
Old Jul 21, 2011 | 12:09 AM
  #27
Repzard's Avatar
Repzard
Hey Kill..Is that including 96-98 Cobras as well for the rears ?
Thanks Ahead
Old Jul 21, 2011 | 10:44 AM
  #28
Kmelfi11's Avatar
Kmelfi11
I think itll look good once you get the wheels from me and make them skinny. They will also perform good enough for your platform.
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 15, 2015 07:34 PM
vintageaion
Sep 8, 2015 10:45 AM
