question on bullet cam
Old 07-20-2011, 03:32 PM
gears94gt
gears94gt's Avatar
Default question on bullet cam
when i purchased the car it already came with a set of cams, looking at the specs, can i run a vortech supercharger with them?. i have read several threads on cams but am still confused, any help will be appreciated. the car made 265rwhp/ 285rwtq on a mustang dyno on a hot humid day.
gears94gt is offline
Old 07-20-2011, 04:46 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
prolly not, LSA is 109 which is really narrow, power adders like a wider angle like 112+
those look like stg 2 NPI cams from MHS btw
sn95_331_GT_ yellow is offline
Old 07-20-2011, 05:55 PM
gears94gt
gears94gt's Avatar
they are stage 2 npi cams, am currently running a 125 nitrous shot with no problem but am tire of the filling of the bottle so i thought i run a s/c instead.
Old 07-20-2011, 05:59 PM
97stanger
97stanger's Avatar
agreed, they have decent duration but lsa is not there at all
I run custom grind bullet racing cams with my setup and specs are: 533/571 lift, 220/230 duration, 114 lsa
97stanger is offline
Old 07-20-2011, 06:00 PM
LilRoush
LilRoush's Avatar
You CAN run a supercharger, but there would be better cams out there if you were to buy a different set.
LilRoush is offline
Old 07-20-2011, 06:03 PM
97stanger
97stanger's Avatar
well of course you can always throw a blower on and just see where the cars at, but if you want to take full potential of your investment in a blower...get new cams
Old 07-20-2011, 06:06 PM
Soldier GT
Soldier GT's Avatar
97 (don't mean to thread jack) would cams would you reccommend??
Soldier GT is offline
Old 07-20-2011, 06:09 PM
97stanger
97stanger's Avatar
I'm a huge fan and believer in custom grinds....off the shelfs will work good but to get a cam ground to your exact specs for the same price seems to be a no brainer to me, but off the shelf I would probably just give CMS or MHS a call and see what they recommend. On a stock internal setup with stock pistons/valves they will probably just recommend a stage 1 blower grind
Old 07-20-2011, 06:15 PM
Soldier GT
Soldier GT's Avatar
Thxs.. you the man!!
Old 07-20-2011, 06:17 PM
97stanger
97stanger's Avatar
haha no problem, dont forget springs either and degree those bad boys as well
Quick Reply: question on bullet cam
