what gears?
Old Jul 24, 2011 | 11:25 AM
scott4.6's Avatar
scott4.6
Default what gears?
what gears would work the best in my 03 gt. i have a 5 speed and was thinking 4.30 s. i like to race in the 1/8 mile. i just want the best performance.
Old Jul 24, 2011 | 11:33 AM
lizzyfan's Avatar
lizzyfan
Underboss
Been asked tons of times
Try the search function
Old Jul 24, 2011 | 11:34 AM
SVTeeshirt's Avatar
SVTeeshirt
if you're only going for 1/8th mile 4.30s might work.... thats kinda steep for a car that redliines at 5850...
Old Jul 24, 2011 | 11:39 AM
mrtstang's Avatar
mrtstang
For 1/8 mile 4.30's would do well.
Old Jul 24, 2011 | 11:49 AM
SVTeeshirt's Avatar
SVTeeshirt
i mean if its a trailor your car to the track type deal, never drive anywhere else you could go 4.56s probably, though idk if you would have to shift another time with the steeper gear. Idk im an 1/8th mile newb.
Old Jul 24, 2011 | 11:50 AM
Blackvenom01's Avatar
Blackvenom01
search bar
Old Jul 24, 2011 | 09:15 PM
TRUEBLUE3934's Avatar
TRUEBLUE3934
I used to run a '86 GT on the 1/8 and used 4.30 gears. It was also my DD.
I would NEVER go with 4.30 gears in a car used on the street. Way to short of a gear for DD duty. LOL I'm pretty sure my 1-2 gear change was within the first 60' with the 4.30s on slicks.
I would go with 4.10 gears. Depending upon how much power your car has, you could probably run thru the traps in 3rd gear with the 4.10s. I would calculate your rpms at the finish with the different gear ratios before you just throw a set in and get disappointed.
GOOD LUCK!
Old Jul 25, 2011 | 05:32 AM
uberstang1's Avatar
uberstang1
Chupacabra
I know alot of people are throwing their thoughts out there about gears, then the debate on RPMS with the gear ration and what not. Without knowing what tire size you are running there is NO WAY to accurately make a decision on a rear gear ration. You throw out 4.30s and people start saying its to much gear gonna be revved high street driving and run out of gear etc etc. If you run a setup that turns out to be a 28 inch tire, a 4.30 gear will have the same exact final drive and RPM as running a stock setup with a 3.90 gear ratio, which is perfectly fine for the drags as well as street driving.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
