Help: CHECK ENGINE LIGHT
Old Jul 26, 2011 | 10:17 AM
sonicx's Avatar
sonicx
speed'n
Unhappy Help: CHECK ENGINE LIGHT
Hey guys... I could really use some guidance/help here. My check engine lights come on. I just got back from O'rileys and using their code scanner. Two codes came up:
1. P2272
O2 sensor signal (stuck lean - Bank 2 Sensor 2)
2. P0060
H02s heater resistance (Bank 2 sensor 2)
Really appreciate it. Thanks
Old Jul 26, 2011 | 11:18 AM
Repzard's Avatar
Repzard
To me looks like you have a bad O2 sensor (bank 2) or a short at wiring to O2
Old Jul 26, 2011 | 03:04 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
^+1...
Old Jul 26, 2011 | 03:29 PM
sonicx's Avatar
sonicx
speed'n
So if I fix it... will that take care of both codes?
Also how do I know which 02 sensor?
Thanks
Old Jul 26, 2011 | 04:12 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
bank 2 sensor 2 is the driver's side rear 02 sensor. I have seen harness for the 02 sensors get pinched by the cross member and exhaust and cause issues. So double check the harness before you condemn the sensor itself
Old Jul 26, 2011 | 04:19 PM
gregor185's Avatar
gregor185
i agree with white fox
Old Jul 26, 2011 | 05:03 PM
sonicx's Avatar
sonicx
speed'n
Interesting, so the code isn't the passenger rear o2 sensor? But the driver's side (only asking because someone else told me it was the passenger). Just wanna make sure whos right and whos not.
Old Jul 26, 2011 | 08:12 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
They were wrong, bank 2 is the driver's side...
Old Jul 26, 2011 | 10:05 PM
sailorflavor's Avatar
sailorflavor
^+1 you can count on cliffyk to be right
Old Jul 26, 2011 | 10:36 PM
scottybaccus's Avatar
scottybaccus
Yup, That's where to start, but remember there are no sure things.
If the issue persists after changing it out, you have more serious issues that will need real diagnostic.
Remember to clear the codes and give it some time to re-learn idle and cruise before expecting it to settle in.
