Solid clutch quadrant... which one?
I'm getting the firewall adjuster but which quadrant is better? Based on what I read I think using a factory cable is best, but do all 3 of these work with the factory cable?
I was thinking of getting this one:
http://www.americanmuscle.com/maximu...-quadrant.html
But wanted you opinions on these as well:
http://www.americanmuscle.com/stqureclqu.html
http://www.americanmuscle.com/stdohoqu.html
What are the plus' and minus' of each? It's a DD street car; going to be running a stage 1 clutch.
Steeda's 2-hook quadrant will work with the stock cable as well.
AFAIK the only reason UPR made theirs a 3-hook unit was to avoid a patent pissing-match with Steeda--I have never heard of anyone using the 3rd hook (the one farthest from the firewall).
OP, the quick release quadrant will noticeably increase the required pedal force--that's the price paid for the quicker release...
You can get the UPR 3-hook quadrant for $25 to $30 depending on which you select.
What do you guys think of this firewall adjuster vs the one at AM? It's half the price, but does it serve the same purpose?
http://www.uprproducts.com/mustang-b...-adjuster.html
And what the hell is this? Do I need this spacer?
http://www.lethalperformance.com/99-...-spacer-p-3760
