torque converter
anyone know if the Mach 1 converter and theGT converters will swap? i know they are different stalls and i want the higher stall one. i can get hold of a Mach 1 converter for $100.
you are wrong
Your probably referring to what you can foot brake the car too...you will never footbrake the car to the full stall.
For example, if you put a 3500 stall in the car, you still will probably only be able to footbrake to 2500 at the most.
if you put the car in 2nd gear and floor it and watch the RPMS jump, they should jump to about 2500 rpms...which is the stall speed.
Switching to a mach 1 converter is pointless...save up some money and buy a decent 3200-3500 converter.
Having only owned two automatics in my life I had not considered how one might be determining the stall speed, however if indeed the test was to brake the car, and nail the throttle, then as long as the engine is running the converter is obviously not "stalled"...
the converter will allow the engine to rev until it either breaks the tires loose, overpowers the brakes (which enough grip) or the engine stops revving. mine stops at 1700. when i take off it only revs to 1700 before the car starts moving.
I think we are looking at this from at least two perspectives, braking stall speed is always less than true stall speed, which I am certain is what the shop manual specs provide.
So as the shop manual lists similar number for both the GT and Mach 1 converters I think it safe to assume there is no practical advantage to be had by moving to the Mach 1 unit...
