Finally have a master plan for the car - 2000 Mustang GT
#42
FRPP - 3.73 Gears, LSD w/ Carbon Discs & Rear Pinion Flange
Moser - 31 Spline Axles w/ Studs & Rear Diff Bearing Cap Stud Kit
MM - FLSFCs
UPR - LCAs
I have all the parts sitting on my shelf except the axle, LSD and bearing cap kit (axle has been ordered today).
#43
No but a mesh delete kit would look amazing on your car! Congratulations on your list i want to get one of my own up! +1
#44
This list has worked out really well. I've gotten some great (and $ saving) advice and also a single place to consult on my past decisions. Good luck on yours!
#45
need some experienced answers!!! 2000 GT V8 manual 4.6L
I have a lot of vibration in my clutch and stick and it rides rough out of first as if im in a higher gear than the speed im traveling.com also when i hit the gas my rpm shoot up but the car doesnt pick up speed or accelerate as it should. Any suggestions as to what it could be?
#46
#47
Finally got all the axle/gear/lsd/misc install pieces bought!
Now time to find a shop near Albany, NY. Any suggestions? At this point I'm considering driving to Mustang Magic (3-4hr drive) just to know I'll get a good install.
Any cost estimates to install new axles, lsd and gears? I'm imagining ~$400?
How much more to install MM FLSFC and LCAs?
Can't wait to see the difference!
#48
since the LSD is out of the car, you may want to install the gears yourself. gear installs alone cost between $250-500 depending on shop and location. the diff fluid is pretty expensive as well. if you tackle that part yourself, then maybe the install for everything else will be ~$400.
FLSFC install are around the $100 range from what I understand. Don't know about LCA's, but with a friend, the install isn't too difficult to do yourself. May want to get that done with the axles though, they probably won't charge nearly as much since the majority of the work to replace them will be done anyway.
#49
Already have 3 bottles of RP ready to go.
That's what I'm thinking. I'll try and get them to do a line item estimate and if it's $75-100 or more I'll just do them myself.
#50
hmm didn't think about issue with pre-load.. don't know much abt that, would be better to further research the topic. i'm sure any shop with decent human beings wouldn't charge you $75-100 for an item(s) that is less than five minutes to install when all the other work is being considered. although i will say "decent" people seem to be getting harder to find...
