What trans fluid yall running?
Old Dec 6, 2011 | 05:17 AM
  #31
uberstang1's Avatar
uberstang1
Chupacabra
Originally Posted by Crispy2000Gt
whats a good syn fluid, is the amsoil a syn. blend?
I run Royal Purple Max ATF, full syn.
Old Dec 10, 2011 | 09:24 PM
  #32
Syracuse315's Avatar
Syracuse315
Just changed out the current fluid (looked like RP) to Mobil1 ATF, what a pleasant difference. This is also comparing very used fluid to new, so the RP may work just as well.
Couple benefits I saw (some may be in my mind, or helped by simultaneous oil change):
- RPMs seemed to be lower by ~5% (could be from decrease in transmission friction?)
- Downshifting/engine braking RPMs do not raise up as high and/or are quieter
- MUCH smoother shifting & no "notch" right before it engages into the gear.
Old Dec 11, 2011 | 10:38 AM
  #33
FlamingoGT's Avatar
FlamingoGT
The first 2 better be 'in your mind' because if your RPMs are different then that means something along the lines of your clutch is on its way out. In a correctly working system, the engine RPM is directly related to the wheel speed.
Old Dec 12, 2011 | 08:42 PM
  #34
TRUEBLUE3934's Avatar
TRUEBLUE3934
Yup, 10-4 on that FlamingoGT.
I think it is simply the placebo effect.
Old Dec 12, 2011 | 10:40 PM
  #35
Syracuse315
Wouldn't be surprised. I didn't write down the original RPMs so I'll never know!
97SN95GT
Sep 13, 2015 09:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
5.0 kevo
Sep 3, 2015 06:24 PM
