Teskid Block
Old Dec 16, 2011 | 01:58 PM
brent22's Avatar
brent22
Exclamation Teksid Block
I know this question has been asked before but I couldn't find in on the search. If I wanted to do a Teskid 2V build what problems would I run in to? I know the Teskid blocks were in the 4v 96-98 cobras. The only thing I can find on google is the drill of the coolant hole on the drivers side gasket. Any information or advice would be awesome!
Old Dec 16, 2011 | 03:03 PM
school boy's Avatar
school boy
in all reguards, you really dont even have to drill out that coolent hole. im using a teksid in my build with arp bolts and some of the bolts/studs and gaskets are aluminum specific. i havent got to fit the timing cover yet, but ive heard there is an extra hole in the cover you might have to fill. the teksid is a great, lightweight block. good luck with your build!
Old Dec 16, 2011 | 03:28 PM
Jay-rod427's Avatar
Jay-rod427
You absolutely need to drill the coolant hole to use 2V heads on a Teksid block. Everything else is the same. As stated above they take different side main bolts, and a few block specific hardware items.
Old Dec 16, 2011 | 10:39 PM
brent22's Avatar
brent22
Awesome Im debating if I wanna to do the build or not! It definitely seems to be worth it in the long run. Thanks for the info guys.
Old Dec 17, 2011 | 09:42 AM
brent22's Avatar
brent22
If I was to do the build would I need to purchase different headers then the ones I currently have or would they bolt right up to the block?
Old Dec 17, 2011 | 12:05 PM
Bpohlman13's Avatar
Bpohlman13
No the ones you have will work. Just remember, that they have a 4 bolt main rather then just the standard most steal blocks have. Also, the main bearings themselves are different.
Old Dec 17, 2011 | 12:16 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
if youre keeping the 2v heads then no theyll be the same...
Old Dec 17, 2011 | 01:18 PM
brent22's Avatar
brent22
Sweet great info guys... The weight difference of the Teksid is about 90 pounds which would lighten up the front end alot too.
Also would my current Procharger bolt right back up?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
wraith777
Sep 28, 2015 10:49 AM
