Help with ignition
Old Feb 4, 2012 | 03:44 PM
96GTStang559's Avatar
96GTStang559
Default Help with ignition
Well i was a idiot and lost my keys. Called a few lockmith and most of them coudn't come out till thurs, so i decided to change the ignition myself.
I first tried drilling through the center to break it and turn it with a screwdriver, couldnt get it to sping.
Then i drilled out the pin on the bottom, That realesed the cylinder.
I mutulated the old ignition and i took all apart without as much car as i should have in my rage. lol somewhere in the disambly i removed the top portion of the lock.
Now trying to install the new lock. I relize in order to get the lock in i need to move the postion to run on the new lock and the columun, Okay great key is in and it spins. clicks 3 positions but has no spring tention when trying to start.
I figure i plug power back in and see if atleast get power to the key, nothing dead.
while removing the old ignition i believe i broke this piece.
With all this said not sure what to do, Car is somewhat a track car, so i am not opposed to putting a push start. What is my best option here. Im just hoping i did not break the column. With what i know now i could do one in 30 min i just cant figure what i broke or didnt set write here,
thanks guys
Old Feb 4, 2012 | 04:58 PM
96GTStang559
found that i was missing a main piece the metal one with the teeth put it lined up, and tried to do key relearn but it only blinks for a min then goes off. tried to start and it starts then dies. i take it that blackwire and ring are for pats?
Old Feb 4, 2012 | 07:00 PM
Bpohlman13's Avatar
Bpohlman13
You need to disable your pats system to work.
Old Feb 4, 2012 | 07:26 PM
96GTStang559
okay so i got the key in power on. theft just flashes will start then die. I realized i have broken the wiring to the ring that goes to the key. Can i just get that part i noticed it can be removed from the module. or is there a bypass module that works
Old Feb 7, 2012 | 03:30 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
The "ring" is the antenna for the PATS transceiver, you'll need a new one--or have PATS disabled in the tune. There is no commonly available bypass module or "trick" of which I am aware....
Old Feb 7, 2012 | 04:57 PM
uberstang1's Avatar
uberstang1
Chupacabra
I must say im very perturbed by the fact u set a pair of pliers and a metal ignition cylinder on a painted surface of the car, but ya u need to do something with the passive anti theft
bradleyb
Nov 27, 2015 07:50 PM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jessicarabbit
Sep 25, 2015 12:41 PM
Wombatnation
Sep 13, 2015 09:16 PM
