Harness and Harness Bar?
Old Feb 13, 2012 | 01:06 AM
CBRKNIGHTRIDER's Avatar
CBRKNIGHTRIDER
Default Harness and Harness Bar?
So I picked up a set of Sparco replica seats off ebay(Seat link )
last week to replace my worn out factory seats. After a couple of hours of figuring out how to mount the factory brackets to the new seats, the new seats where in and they looked and felt great. I am currently using the factory seat belts, but don’t like the feel and look with the new seats. So I went on AM to look for a harness bar and harness to use with the new seats but they are out of my price range. I came across an adjustable harness bar and 2 four point harness on ebay for under $180(http://www.ebay.com/itm/49-STEEL-HAR...item35b8466a9e)
So my questions are:
1) Has anyone used or heard of using this harness bar and harness in their car?
2) Is it a good idea to use a harness instead of a factory seat belt? ( I don’t do much racing or any track time, so they will be basically for looks)
3) Can someone still get in and out of the rear seats with the harness bar installed?
4) Can a four point harness be installed without using a harness bar?
Thanks in advance for any help of advice given to me on making my decision.
Old Feb 13, 2012 | 01:10 AM
Bpohlman13's Avatar
Bpohlman13
Save up for the proper harness bar. If it fails. you could go flying through your windshield in a car accident. cheaper is not always better.
Old Feb 13, 2012 | 01:45 AM
oxfordgt's Avatar
oxfordgt
Don't rice your car out.
Old Feb 13, 2012 | 03:06 AM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
brakes, seats and harnesses/cage are the only areas of my i WOULDNT cheap out on...
keep that in mind...
Old Feb 13, 2012 | 10:27 AM
school boy's Avatar
school boy
you could use your factory rear upper seat belt attachment points. these points are designed in the body structure to be pull points. im not sure exacty how much presure they're ment to hold but its well above whats needed. i have used these myself with my harnesses and work really well
Old Feb 13, 2012 | 10:35 PM
JRad405's Avatar
JRad405
^That. You need to have the proper support and those ebay ones you posted won't do it.
Old Feb 14, 2012 | 06:01 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Cheap, fast, safe
You only get to pick two...
flash_xx
Oct 16, 2015 07:23 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
breaking
Oct 2, 2015 01:27 PM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
