03 GT
03 GT
Hey guys,
I bought this car a little while back in august....I want to know what performance parts you would get....Exhaust, Sway bars, ford racing spark plugs? not sure....I love Mustangs, i can take them apart from the ground up but i need some input on what parts to buy...I was looking at Borla for an exhaust. My cash limit is prolly around 2g....
anything will help! Thanks!
^ agreed. Otherwise I would just go with the norm CAI and exhaust to get her breathing better, a tuner, and some tokico shocks and a good set of springs. If you have cash left over get new rims and tires. That should just about burn up all that cash and maybe leave some for gas.
OK, here's my 2¢ worth:
Other stuff is largely a waste of money. The stock airbox and intake tube are entirely adequate for any n/a setup, as are the stock COPs and any single platinum plug.
If you are the sort that winds the engine up hard in the lower gears then UDPs can add some spirit. If however you are the sort that shifts at 3500 rpm don't bother as you will never know they are there, same holds for lighter flywheels and aluminum driveshafts. They only add zip under had and fast acceleration.
That all will eat up a grand or so, if you do the installations.
Save the rest for suspension work, or going f/i down the road...
- Upgrade the exhaust: 2-1/2" from the manifolds back, X or H-pipe as you prefer, catted or off road as it doesn't matter in terms of power gain;
- Buy a tuner: handheld or PC based, load a tuned optimised for the highest octane fuel you are willing to buy--however as the stock tune is so bad (very conservative ignition timing and quite rich at WOT) even a "87 octane" canned tune will noticeably wake things up;
- Rear-end gears: 3.73:1 or 4.10:1 as you prefer, you can use my How Fast Can I Go in Each Gear? calculator to see what effect various gear ratios will have on mph vs. rpm;
- Upper plenum: This is the weak link in the intake, any after market upper plenum will outflow the stock unit even with the stock 65 mm TB. Do a 70 mm (or 75 mm if you want, 70 is all that's needed) TB too--read more about all this here;
Hey guys,
For another 70 bucks you can have my same S/C setup including the intercooler. If not that route, I would most def take advice from cliffy, slong with a MGW STS.. Congrats on the ride my man..GL!
