School me on fuel injectors!
Old 05-06-2012, 02:47 PM
jtb727
jtb727's Avatar
Default School me on fuel injectors!
I'm looking around at fuel injectors for my vortech build. I know almost EVERYONE that does the build runs 42lb. injectors. However,I've read that I need EV6's with the jetronic correct? I see there are EV6 and EV1's and also Jetronic and USCAR... How can I tell the differences between all of these options? Are any better than the others? I know there are ev6 and ev1 adaptors to adapt to both. I also see that brothersperformance.com has FRPP 47lb injectors for a pretty good deal, however they are USCAR and EV6. Would these work? I'm not finding FRPP 42lb injectors only the venom ones.
Thanks
jtb727 is offline
Old 05-06-2012, 03:33 PM
stevednmc
stevednmc's Avatar
EV6 and EV1 etc are the design of the main body of the injector. Jetronic and USCAR are the connector types. You can run any of them, just keep in mind if you buy injectors with the USCAR connector you'll need an adapter for the connector.
stevednmc is offline
Old 05-06-2012, 05:18 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Steve is dead on, I recently posted this on another forum:
EV1 and EV6 denote different body styles; and each can have either the Jetronic/Minitimer or USCAR connector. As long as the injectors have the Jetronic type connector they can be used in our cars without an adapter.
I run the M-9593-AA302 FRPP 24lb/h injectors (now discontinued), they are EV6 body style with Jetronic connectors.
cliffyk is offline
Old 05-06-2012, 05:20 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
deleted, double post...
cliffyk is offline
Old 05-06-2012, 07:48 PM
jtb727
jtb727's Avatar
So can I get these? :
http://brothersperformance.com/p-401...connector.aspx
http://brothersperformance.com/p-119...-to-uscar.aspx
and be okay?
I know most guys run 42lb. injectors but I cant find them for a reasonable price.. and for my fuel system, I'd rather buy everything new. (pump, injectors)
jtb727 is offline
Old 05-06-2012, 09:58 PM
stevednmc
stevednmc's Avatar
That should work fine for you as it would only reduce the duty cycle. The tune will be the deciding factor here, the injectors will only do what they are told to do by the pcm. They just have to be capable of more fuel flow to meet the needs of the forced induction.
Old 05-07-2012, 12:12 AM
scooter3
scooter3's Avatar
Check around on the adapters. You mght be able to get them a little cheaper then that.
scooter3 is offline
Old 05-07-2012, 08:21 AM
MCxQubed
MCxQubed's Avatar
also check out corral.net, i got my green top 42# on there for 185 shipped to my door and they work perfect
MCxQubed is offline
Old 05-07-2012, 06:50 PM
jtb727
jtb727's Avatar
I found some 39lb ones for 169.99 I may jump on.
jtb727 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: School me on fuel injectors!
