bad Gas leads to missfire....??
Old 05-20-2012, 11:30 PM
01FPGT
01FPGT's Avatar
Default bad Gas leads to missfire....??
So I should say it wasnt bad guess, but a dumb mistake by my bro who put 87 octane in my 01 gt when its tuned for 93. It ran like crap which lead to a CEL. Drove a few miles thinking it was just the gas and went home to siphon most of it out. I was able to and just burned off the rest. Now CEL came on and ran the code which read missfire in Cylinder #2.
I pulled plug and that was ok. I have new NGK plugs. I checked the Weapon X coil and nothing out of the ordinary. So I switched the coil to another position and wiped the codes. The car is driving a lot better but still has a small hesitation problem. Im hoping to get another CEL telling me missfire is in another cylinder so I can def know that its the coil. If not could it be the injector thats clogged? Can I pull the inj and clean it by spraying or blowing air into it? any suggestions or comments please let me know? I know some people have had issues with Weapon X coils...I do have the blue procharger 42LB injectors in there now.
Thanks for the help
01FPGT is offline
Old 05-21-2012, 11:29 AM
Barley
Barley's Avatar
I had misfires due to old gas before. At first it was giving me codes for bad coils, when I checked them all it started giving me codes for misfires due to the spark plugs. Eventually, I started driving hard on a fresh tank, and magically they all dissapeared.
Barley is offline
Old 05-21-2012, 11:48 AM
Derf00
Gentleman's Relish
Derf00's Avatar
93 and 87 are worlds apart. Until you have every drop of 87 gone the code will probably stick around.
As long as you don't WOT while you still have 87 octane mixed in or get on it alot, it won't do any damage. It will just suck.
Probably take one or two tanks of 93 to get back to normal.
Don't have an 87 octane tune?
Derf00 is offline
Old 05-21-2012, 04:28 PM
01FPGT
01FPGT's Avatar
Hey guys, no I don't, I used to before I got tune for the supercharger, for some reason my tuner didn't use my chip bank.. Ok I panicking bc I think it's my coils but I'm gonna head to the gas station and keep adding some fresh 93 octane .. I was worried bc I heard that weapon x coils were not the best..
01FPGT is offline
Old 05-22-2012, 11:20 PM
01FPGT
01FPGT's Avatar
so update..coil was not the problem, spark plug was. I pulled it and it was wet with oil on the threads and close to the tip. I dont think that is a good sign... I drove around after installing spark plug but im guessing the misfire will come back after a while of driving..
01FPGT is offline
Old 05-23-2012, 12:00 PM
boduke0220
boduke0220's Avatar
Not good at all dude. Worst case scenerio the 87 made the car detonate so bad it blew the ring lands. what you should have done is parked it. drained the gas and put 93 in there and let it idle for like 30-45 mins untill the 93 was in the system
if you can get a light, take that plug out and look down in there which might be kinda hard or get a Q-tip ( with no loose stuff on it) and swab it and see how much oil was in there.
boduke0220 is offline
Old 05-23-2012, 02:54 PM
01FPGT
01FPGT's Avatar
thanks boduke, i did it last nite, there was enough to not drench the plug but there was residue along the threads..I have a feeling cylinder is screwed as well. well have to wait and see.
01FPGT is offline
Dathan
10-05-2015 05:52 AM
b8checker
09-30-2015 07:11 AM
kartracing87
09-28-2015 11:01 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: bad Gas leads to missfire....??
