engine running on 5 cylinders
start engine runs fine first 5 minutes then 3 out of 8 injectors dont work or if you unplug them motor runs same just changed plugs and switched injectors around and same three everything works runs fine until warms up then misses bad dont know what it is but its not injectors. any help?
I'm having a hard time understanding your post due to sentence structure, so are you saying your injectors arein't pulsing? Did u try removing spark of those cylinder when it runs to see if anything changes
At first glance it sounds as if you're saying you have pointed the fuel injectors as culprit, but depending on how your jumbled mess of words is interpreted it sounds like the injectors are not the problem.
Pull the plug wires one by one in the same manner you did the injector plugs and see if it changes the way the motor runs.
The problem is pulling the plug of the injector and it not changing how the motor runs doesn't mean anything untill you confirm that the cylinder is getting spark first. Because with no spark that injector could be working just fine, the no change is due to the fact there could be no spark to ignite the fuel.
bryan616fl
Jan 25, 2019 09:07 PM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
