Repin diagram 98 4r70w into 96
Well I found a chassis connector diagram for 98-2004. Problem is (don't laugh) my buddy tells me just cut the wires and change them around and reconnect with butt connectors. I did that first unfortunately I was backwards so I actually repinnned it the right way, or so I think, and the o/d light flashes. I have a 96 gt, installed the 98 transmission. I need help with repinning the chassis connector. If I have to grab another harness from a 96 and repin it the right way, with out cutting the wires ill do that. Just need help with the whole procedure. Read somewhere that after repin you have to use the 96 sensors? Is that correct? Thanks for any help! Reallllly appreciate it.
RePin diagram
Look way down on this chart.
I am doing the same thing to my 96 GT. I already have the tranny and just educating myself before I swap em. Let me know how it goes please!!!
http://www.oldfuelinjection.com/?p=88
I got it all in. Took a while to gather up the right info. Do yourself a favor and take the time to repin te connector the right way, like taking each wire out and doing it the right way. You'll need the connector diagram for the 96, to get the proper wire color, an the 1998-2004 connector diagram, (black transmission). I doubt I can post pics.
Here is what ou need
http://clickclickracing.com/4rrepin.pdf
It's a pretty amazing deal big difference I have stage 1 transgo, shift kit in mine pretty damn sweet
