My own personal quest for a 300rwhp N/A 2 valve Mustang GT
God, I hope you wouldn't need all that! 5 years ago in made 320/333 on a mustang dyno with the stock MAF, stock intake and inlet tube. This was before the trickflow heads, etc hit the market. I know there a big difference between 320 & 340 but a 5.9L??
BUMP!
So I am looking to tear into the car and can't really find a whole lot of info on ported heads with "Hitech" stage 2 cams.
From what I have gathered you only want to port the intake side "only" and not polish, since the 4.6's seem to like turbulence in the cylinder head and porting the exhaust side is a bad idea with "Hitech" stage 2 n/a cams.
So just looking for some clarifacton on that.
Also I'm looking to upgrade but not sure which brand to go with for valve springs and differant pistons to give me a nice bump in compression.
So final ugrades I am wanting to do are
-port heads (intake side only?)
-24lb injectors
-valve springs
-differant dish of pistons.
-24lb injectors
-valve springs
Sorry for the same question as asked above! Didn't flip page before I responded to his 340 claim.
Last edited by TRUEBLUE3934; 02-03-2013 at 07:45 PM. Reason: Flipped page and saw others had asked the same question...
-24lb injectors
-valve springs
-24lb injectors
-valve springs
Cliffy will no doubt tell you that 300rwhp on the 19# injectors are 100% maxed out at WOT and you are risking going lean.
As for injectors, since it is an 04 it actually came stock with the pink top #21lb injectors...figuring might as well upgrade a bit to the #24lb injectors
Sounds good, I plan to go to Omaha quite a bit this year for cruises especially the Wednesday night Sonic cruises
