2000 GT sputters when accelerating
Old Apr 8, 2013 | 04:56 PM
kkroll86's Avatar
kkroll86
Angry 2000 GT sputters when accelerating
for starters i have a 2000 GT with a 4.6 and it has 144,000 on it. the only thing that has been changed is there is SLP load mouth exhaust and a chrome intake put on.
So last summer i was having a problem when i was giving it gas or putting it under a load, it would sputter ( can tell starting in 3rd gear). So i went through and changed all the plugs and ignition coils. Car ran good for about a month or so. Then the same problem started coming back and it threw a CEL. I got it scanned and it said there was a misfire on a cylinder 1. so i changed one of the injectors figuring that would be the problem...didn't help. so i went to the fuel filter and changed that thinking it was probably just plugged...ran a little bit better but it still has that sputter. I am looking for a couple more things that I can do for myself before i bring it in to get looked at.
Old Apr 8, 2013 | 05:19 PM
edwin108's Avatar
edwin108
Try clearing the codes and swapping the number 1 coil with another good cylinder to see if that coil is bad.
Old Apr 8, 2013 | 06:27 PM
Seabee1993's Avatar
Seabee1993
+1^ I concur
Old Apr 8, 2013 | 09:26 PM
69MustangCoupe393cid's Avatar
How's the wiring look on the coil/injector on the problem cylinder? Maybe it's screwed up and when you move it you fix it, then vibration ruins it again and makes it short.
Old Apr 8, 2013 | 09:34 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
98.9% of the time a misfire on a modular motor is a coil problem. Why you decided to chase the fuel side down and blow useless money is beyond me.. Replace the coil and plug on the cylinder that is throwing the code... problem solved
Old Apr 9, 2013 | 10:32 AM
kkroll86's Avatar
kkroll86
Well I already did change the plug and coil on the problem cylinder this is why i was leaning towards something different
Old Apr 9, 2013 | 12:40 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
did you replace the coil with OEM ones? if no, see my last post
Also, if its a problem you cant solve quickly and cheaply, then maybe take it to a shop and get it fixed right instead of tossing parts and wasting $
only other thing I've seen with these cars is the fuel pump dropping pressure.. But the car will not rev past a certain rpm under load when this is the case. If just one cylinder is missing, then its not a supply problem
Old Apr 9, 2013 | 01:26 PM
kkroll86's Avatar
kkroll86
WhiteFoxGT it was a junk coil... i went and bought another coil and moved it around and found that there was a bad one..problem solved thanks
Old Apr 9, 2013 | 02:17 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
glad you got it sorted.. sorry if i sounded a bit rude however it hurts my head when I see others throwing parts at their cars
GimpyHSHS
19
Dec 19, 2023 01:12 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
Offendant
Sep 23, 2015 07:21 PM
trashxtrash
Sep 20, 2015 10:49 PM
rksnow1
Sep 14, 2015 08:46 PM
