tuneup
Old Oct 27, 2013 | 07:17 PM
dolphinsrok's Avatar
dolphinsrok
Default tuneup
hi so i finished the tuneup on my 70,000 mile, 03 gt which i had for a year and haven't done this yet. Car has been running rough lately, hesitating a little bit in the higher gears after I ran over a big puddle 3 months back, still hesitating a little bit just finished doing this:
- installed cai from american muscle
- motorcraft plugs and coil boots
- motorcraft fuel filter
- changed engine oil
- changed manual tranny fluid
This made a nice difference, everything is much much smoother, shifting gears feels nice.
I had everything for a rear diff lube change but couldnt get the frigin fill plug off. It was to tight, didn't want to break something so i'll take it somewhere with a lift. Ill post pics of it soon!
Old Oct 28, 2013 | 02:48 PM
AMWill's Avatar
AMWill
Former Sponsor
Nice call on the tuneup! The only thing I think you're missing is cleaning the MAF sensor. If the car has been running rough every since you ran through a deep puddle, there's a good chance the MAF was exposed to dirty water.
Pick up some MAF cleaner from your local auto parts store. Use it sparingly, but clean the MAF up. I think you'll find this is the last factor that's causing the car to run rough.
Let me know if this helps!
Shane
Old Oct 28, 2013 | 02:55 PM
uberstang1's Avatar
uberstang1
Chupacabra
Any check engine codes?
Old Oct 30, 2013 | 09:08 AM
brownb2's Avatar
brownb2
+1 on the codes.
Old Nov 1, 2013 | 03:36 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
water will smoke the coils from time to time, replacing just the boot might not have been the answer.
Old Nov 1, 2013 | 09:20 PM
dolphinsrok
So after the tuneup, it was definitely much smoother and even shifting gears is a bit smoother. I'll look into MAF cleaner because I think it should run a little smoother and also now that I have the cai, I noticed, I', getting a "check engine soon" light on the dash which I think is probably gonna throw a code for the MAF. I see rockauto has the motorcraft MAF for $164, I'm sure if I put back the stock intake it will probably make the code go away so no need to buy one but I will clean it, thanks everyone! appreciate the help.
Bagitupbaby
Nov 1, 2007 09:54 PM
AJ06GT
SVT Forums
Oct 27, 2007 05:07 PM
Aereon
Nov 15, 2006 02:28 AM
99Stang_V6
Feb 24, 2006 11:42 AM
sabearn
Jul 16, 2005 10:28 PM
