Coming Along..
Old 11-24-2013, 09:10 PM
Soldier GT
Soldier GT's Avatar
Originally Posted by 72MachOne99GT
Gotcha, I figured with some of the other supporting mods you could maybe close in on 600s..
Is 400s going to be a pretty conservative tune?
I'm gonna try to get her to 450 to 470 on the current setup. Just worried about the pump. The engine it's self willl be capable of mid to low 6s but my Achilles heel will be the pump. I currently have a 255 walbro pump with a 40 amp BAP so I should be able to reach my goal (if all goes well) . Hopefully the high flow fuel rails and 55 lb injectors will help out.
Soldier GT is offline
Old 11-24-2013, 11:22 PM
Bman2000
Bman2000's Avatar
yea youd need a 3.0 upper and 18% od crank to pull 600s, but beside the fuel issue, im wondering if your running water meth? Cuz if i read right you have 11cc dish? Isnt that a higher than factory compression ratio? Do they have notches for bigger cams in the future? We have some similar stuff going. Heads factory? By the way what is your tial? is it the 50mm BOV? If so its same as i have, curious where you hooked it up for vacuum, cuz first place i hooked it up it fluttered(not good enough vacuum) sounded cool as hell but when i gave it a good strong signal all the flutter went away.
Bman2000 is offline
Old 11-25-2013, 07:40 AM
CobraFrenzy
CobraFrenzy's Avatar
glad to see it finally coming together
CobraFrenzy is offline
Old 11-25-2013, 12:40 PM
99 GT vert
99 GT vert's Avatar
cannot wait to see this thing back together and running again. with the proper fuel system and more boost I see no issue hitting high 5xx rwhp
99 GT vert is offline
Old 11-25-2013, 12:58 PM
lizzyfan
Underboss
lizzyfan's Avatar
Awesome brother!!!!!!!!!
lizzyfan is offline
Old 11-25-2013, 01:44 PM
Soldier GT
Soldier GT's Avatar
Thanks guys. You all know what I've been through with this car. Took me a long time and a lot money to finally realize that some things you can't take short cuts on and the cheapest installer may not be the best. Also Lizzy I forgot to mention you to as a person that has given me a lot of good advice and it is much appreciate. I'm gonna call today and make a tentative dyno date for 20 Dec. I'm going to check on the car next Wed so I'll keep you guys posted.
Couple questions. How much work or fabrication is needed to be done to make the cobra fuel tank work on my car. Are there any other alternatives? Is there a fuel pump out there for the New Edges that can be installed in my current tank that can handle over 550 rwhp?
Old 11-25-2013, 04:32 PM
99 GT vert
99 GT vert's Avatar
you bolt in the fore dual pump hat into a gt tank you just won't have the baffling like a cobra tank. and the cobra tank is a direct swap I believe
Old 11-25-2013, 07:52 PM
Gt04
Gt04's Avatar
Cobra Tank Is A Direct Swap
Gt04 is offline
Old 11-25-2013, 11:27 PM
Bman2000
Bman2000's Avatar
everything cobra is a direct swap, the cars are the same, only the parts are different...pretty much. Anyway dont do a gt tank with the dual hat like i did, thats what cost me the motor. Its not so much that you cant i guess, but i had a 1/4 tank and no baffling power shifted 3rd sloshed fuel away from the pumps had one go round of lean, hard miss car fell flat on its face...ran fine for about 10 miles, then piston cam into contact with the crank. Long story short i starved the motor for a split second bent a rod. said rod is now sitting on kitchen table pissing my wife off...lol Anyway minimum i would have baffling welded into current tank, or never run below a 1/2 to be safe, cuz i broke the car with 360rwhp. only issue with keeping it above half....well you probably wont be able to pass a gas station if you have any fun driving it. lol
Bman2000 is offline
Old 11-26-2013, 06:46 AM
99 GT vert
99 GT vert's Avatar
I agree with bman definitely do the cobra tank but if it isnt in the budget before yiu get a tune at least get the dual pump hat so you are not wasting money on a second tune
Quick Reply: Coming Along..
