99 Stage 2 Roush rebuild issues
Old Jan 9, 2014 | 11:34 PM
99RoushMMR2's Avatar
99RoushMMR2
Default 99 Stage 2 Roush rebuild issues
I rebuilt my 4.6 and all went well started first time during intial test break in drive went well with no intial problems noted till about 10 miles it backfired a few times nothing rapid or seemed to be alarming although it would load well during increasing to 50 mph and coasting back to 30 to help seat rings it seemed to delay loading when intially beginning to coast back to 30, then all the sudden like a light switch engine shuts down, upon initial inspection noted left cam sensor came disconnected no other issues noted except would not restart and seemed like it is not firing except an occasional backfire. Any tips or thoughts would be appreciated
Old Jan 10, 2014 | 09:00 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
air/fuel/spark <~ engines need those 3 things
Check fuel supply at rail, check codes to see if an ignition failure.....and please work on sentence structure and punctuation. What does "load well" mean?
Old Jan 10, 2014 | 09:39 AM
99RoushMMR2
Thank you, sorry for bad description it was firing excellent, the acceleration and the rpm was building up rpm good as I ran it up to 50 mph.
I left out it also blew a couple fuses one to the radio and dash panel. I will check the rail now and I appreciate your thoughts.
Old Jan 10, 2014 | 07:15 PM
99RoushMMR2
I replaced blown fuses and the stereo still did not come back on, all dash indicator lights that come on as you turn on ignition comes on except the odometer. I am looking for any good information.
Old Jan 11, 2014 | 09:26 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
go back and recheck all your connections and grounds
its obvious you missed something. unfortunately there isnt a thing we can do through our keyboard screens
Old Jan 11, 2014 | 02:39 PM
99RoushMMR2
Thank you, I will do that and I will post what the issue was when I find out what the problem is as I am sure its an issue that will be helpful to others, after all it is what makes forums so awesome.
Old Jan 11, 2014 | 05:32 PM
99RoushMMR2
I apologize for asking a trival question but can leaving the cataletic converters unconnected cause this problem on a 99 model if so will simply plugging them back up fix the problem ?
Old Jan 11, 2014 | 05:42 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
disconnected? as in open headers, or do you have an offroad midpipe?
either way, no thats not your driveability or cluter problem
Old Jan 13, 2014 | 12:42 PM
99RoushMMR2
I appreciate your help and sorry for my English is not my strong point never has been although my back ground is weapons and pu238 from the Air Force and Los Alamos which is all technical stuff that is all by the books stuff which is why I even attempted this in the first place and forums where I can ask questions to pros like you is priceless.
I found that the problem was a bad cam sensor it had came apart from the cam gear almost come off the cam and broke it off. I replaced it and have made sure all of it is out and put it back together but it seems like it is not even trying to fire, is there anything else it could have caused issue's with ?
Old Jan 13, 2014 | 12:44 PM
99RoushMMR2
Oh I forgot to mention I now have cam end bolts in place.
bjdutch2005
Mar 24, 2017 03:38 AM
9550
Oct 26, 2015 05:01 PM
warwickbass
Sep 20, 2015 04:51 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
