brake vibration HELP
I have a 2000 Mustang gt and when i brake from interstate speeds i get some vibration that gets worse with more pressure.
Sometimes after a somewhat hard braking a slight vibration will stay while driving and not using the brake for a little while then fade out.
I have noticed after parking that my right rear caliper is a decent bit hotter than the rest, but the car never pulls one way or another while braking or driving.
Any suggestions will be appreciated. I will be taking off the right rear and inspected whenever i can finally get home.
Thank you and God bless
Sorry for late reply. Turned out the right rear brake caliper was stuck in a position that just put the pad close enough to the rotor that the pad would shake side to side on it i guess. Piston wouldnt expand or contract. Completely stuck
Whitefoxgt, I was not aware of that. Do you mean that the piston actually more resembles like a hydraulic ball screw kinda? Or if you can describe it that would be great. But either way it would NOT budge in any way even when it was completely disconnected from the brake line
Hmmm.... that may have been it! Although when i took it off and compared to the new one, the position of the e-brake spring looking attachment was in the same position as the new one... so i think the piston was just stuck? Thanks for the info! Learned something new today
