Idle Issue help
Old Jan 18, 2015 | 12:55 PM
BPx07's Avatar
BPx07
Default Idle Issue help
Anybody have/had an idle issue? It idles fine at a cold startup, however when the engine warms up after a drive; when at a stop in first or in neutral it fluctuates between 900 and sometimes gets down to 400/500 and then jets back up to normal idle rpm. Done some research but have seen many different causes. It currently has a tune and a JLT intake on it as well. It's an 04 with 44k miles on it
Old Jan 18, 2015 | 01:00 PM
Soldier GT's Avatar
Soldier GT
What kind of tune? Have you Checked your IAC?
Old Jan 18, 2015 | 01:37 PM
BPx07's Avatar
BPx07
I bought it used a month ago from a dealer. The previous owner had a BAMA tune already programmed on it, I do have the tuner. I haven't checked anything yet no, just wanted to do a little more research before I dove into it
Old Jan 18, 2015 | 02:43 PM
Soldier GT's Avatar
Soldier GT
Might wanna take it back to stock. No reason to put a tune on a car that only has a intake.
Old Jan 18, 2015 | 03:50 PM
school boy's Avatar
school boy
I agree with soldier, take it back to stock and see if it runs any better. If not, try cleaning the iac, they tend to get dirty and cause problems. Also check and see if everything is air tight on the jlt intake.
If the programmer isn't the problem and you get everything lined out with the idle, you can try the programmer again. I personally don't see anything wrong with using it if its not causing problems.
Old Jan 18, 2015 | 05:49 PM
BPx07's Avatar
BPx07
Ok I'll give that a shot, thanks
Old Jan 20, 2015 | 08:19 PM
BPx07's Avatar
BPx07
After what point is a tuner beneficial? Mods wise
2007StangV6
Jan 28, 2016 06:09 PM
stangin1996gt
Sep 21, 2015 11:01 AM
LivingInThePast
Sep 16, 2015 12:20 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Emblazoned
Sep 3, 2015 10:45 PM
