Is this a scam? Brake Fluid Replacement
I have a 2003 Mach 1 with around 130k miles on it. I messed up and let my brake pads on the rear go too far before replacing them and as a result ran out of pad and messed up my rotors... I'm getting new rotors/pads tomorrow, but the shop said I'd also need a brake fluid flush because of debris and dirt coming from the pad hitting the rotors? Correct me if I'm wrong, but there's no way for it to get in there is it? I feel like they're just trying to tack on a small extra charge. So, could this be necessary?
Thank you
Thank you
Thank you
Thank you
Their lack of a decent explanation though doesn't mean it completely negates the need to flush the fluid. Anytime you replace your pads, you should flush the calipers first. Over time, water and dirt from corrosion within the system collects in the calipers. When you replace your pads, you push the caliper pistons into the caliper, this displaces the dirty fluid into the only direction it can go in, back into your brake lines and possible your ABS module or Master Cylinder.
Yes, you should have the fluid flushed but you may want them to re-explain why. Perhaps you misunderstood them or, they really are right for the completely wrong reason.
Any other time I'd do it myself but unfortunately I just started college back and have a job and don't have the time/place to do it. I need my car daily to get to work and need it fixed asap so I'm letting a shop do it. Thanks for the advice guys, I'll probably flush the fluid myself this weekend
