Figured The Problem; Need Solution
Old May 16, 2018 | 06:12 AM
Jon S's Avatar
Jon S
Default Figured The Problem; Need Solution
Regarding my crank no start I have figured out the problem is not the fuel pump but rather the fact the fuel pump is not being primed for three seconds prior to starting The fuel pump will run once the engine is started with starting fluid which means that my crankshaft position sensor is telling the fuel pump to run The real question is why is the fuel pump not being turned on for three seconds when my commission key is turned to start
Old May 16, 2018 | 06:49 AM
GT Nate's Avatar
GT Nate
how's the fuel pressure when it's running? Checked the fuel filter?
Old May 16, 2018 | 06:55 AM
Jon S's Avatar
Jon S
The 2004 has no Schrader valve but I'm assuming Pressure is fine.
This problem developed after I changed my battery and I had to fix the PATS System the THEFT light now goes out after 3 seconds of ignition on and engine does start and run with starting fluid initial spray so I "think" PATS is a non issue.
Nick@Autogeek
Mar 21, 2012 03:52 PM
Fastman
Dec 21, 2006 02:59 AM
cbennett
Nov 7, 2006 04:49 PM
grabbem88
Jun 17, 2006 05:05 PM
chath_brick
Apr 11, 2006 02:17 PM
