power window question
My drivers side window worked fine this morning, but when I got off work and went to leave, the window wasnt working, and still isnt. I took the door panel off, and when I hit the switch to go down or up, I can hear a little click but nothing happens.. does this seem like it needs a new motor or something else? thanks!
Very, Very odd, I thought that if I posted a post like yours I would get wierd replies, but just the other day I had the exact same thing happen to my car. A 2003 GT with 29,000 miles on it. I actually thought that the Diablo programmer had somehow deactivated the drivers side window. I did return the car back to factory tune so that I could take the car to the dealer the next morning. Got up early and touched the window button and what do you know it worked. Well then I put the tune back in and it still worked. Could not go to the dealer because everything works.
Had the same symtems, switched appeared to make it's usual contact because of the dimming of the lights on the instrument panel, sort of like when the window has reached it's travel limit. It was not the fuse because the fuse controls both windows and the passenger one worked fine.
Next question, does anyone else have this wierd problem, have not had a chance to look up any service bulletins.....
spit or kick..i like that...i tried slamming the door a few times and unplugging/plugging in the switch to no avail...i'll try the spit next time
thanks for everyones responses
