Motive Gear or FRPP 4.10's
RE: Motive Gear or FRPP 4.10's
Surprisingly a lot!...lol gears are one of the best bang for the buck mods you can get. Sure, if you dump the clutch at high spin you'll spin the tires but you'll do it with stock gears. The 4.10's will be a very noticeable and happy mod for you.
But yeah, another 'must have mod' would be a good aftermarket rear swaybar, panhard bar, and upper and LCA's. You will feel a big diference I promise you.
ORIGINAL: blowngt
Thanks again,
mike
ORIGINAL: blowngt
No problem - just remember to get the frpp gears!
ORIGINAL: blowngt
[sm=bs.gif]BS - Some of the top installers in the country get whine with the motives. So you're saying Jim & Jim Jr. at JDM, Mike at livernois, Justin at JPC, Adam at ST Motorsports, Mike at powerhouse, derrek at D'agostino, chuck at che DON'T KNOW HOW TO INSTALL GEARS? Cause all of these guys will tell you the motives are bad. Your experience is NOT on S197's and I hate to break it to you but they are just a little bit different than your cars.
FYI I'm at 2900 rpms with 4.10's @ 80 mph. You would likely see 3000 rpm @ 80 with 4.30's.
ORIGINAL: mustangman02232
the only reason gears whine is if they are installed incorrectly. period, end of story, and if its a manual i would seriously look at getting 4.30s with the t3650 tranny, you will be at 2800 rpms at 80 mph and loose liek 3 mpg
oh and two, with a TR-3650 tranny which has an 5th gear ratio of .68 and a stock 21.7 inch tire are turning 2900 rpms? are you an auto? cause if you are, then the 5th gear ratio is .75 which is a bit more believable,
oh and FYI, trannys from 2001.5 5 speeds are the same for the SN_95 and S197s
http://mustangtuning.com/fopege4ra.html gears
http://mustangtuning.com/rearendrebuild.html bering kit
"mustangboards" - 6% off cupon
what does they generation of cars have to do with the kind of gears? my uncle has motives in his maro and there is no whine, another friend of mine has em in his jeep, once again no whine,
ORIGINAL: blowngt
Well, I will throw my 2 cents in. Had 4:10 Motives and they whined no matter what. They were checked and rechecked. Put FRPP gears in a week later and surprise! No more whine. FRPP now uses an updated cnc single pass cut process and also does a backcut on the pinion gear to reduce whine. The new ones are designated by an A after the part number. If you get the FRPP gears with the M designation they will likely whine. Why? Because they are made for Ford by - Guess who! - Motive!
Oh yea, as for the rpm change, I was at 2500 at 80 with the factory 3:55's and now at 2800 at 80 mph with the 4:10's and the acceleration is greatly improved. 5th gear is now much more useful.
