20mph->60mph 2nd gear time test
#21
RE: 20mph->60mph 2nd gear time test
ORIGINAL: richmod
I thought the GT was rated 0-60 around low 5's. So how is 20-60 low 5's good?
#22
ORIGINAL: bluetang
rolling at 20mph (neutral pedal pressure..your not accelerating or decelerating) in 2nd gear..
have timer ready and push start on your timer as you go full throttle at 20mph
have finger on stop of timer and push stop as you hit 60 mph.
I think you should be requred to do each run in opposing directions to null out any "down hill" or "tail wind assisted" times.
-howy
#25
Ran mine tonight. Factory stock 2006 GT 5 speed with 7100 miles on it. 64'F, 5.1 seconds. Changed out to Granatelli CAI/MAF dropped to 4.8 seconds. This is an average of 2 runs in opposite directions.
#27
well run #1 was a 4.63 #2 - 4.78 #3 - 4.80 #4 - 4.72 #5 - 5.08 #6 - 4.78
I think #1 was the fastest because she was still cold and it seems to be consistent with the 4.7 range.
personal test: 0-40 in 1st was 3.20 and 40-60 in 2nd was 2.30. So from a roll 0-60 about 5.5 seconds. Thats pressing start when I lift the clutch and hit the gas. By doing the 2 difernt runs like that i can get 0-60 without the shifting. If i were to launch it would be much better.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Calizic
08-28-2015 01:46 PM
Figure8allday
08-22-2015 11:11 AM
