valve cover torque specs
hello i am new to this site from what i have seen this is the best so far . i am going to put a air intake system on my 06 gt but i have to use two valve cover bolts for the mounting bracket, can somebody tell me what the torque specs are for the bolts. THANKS
RE: valve cover torque specs
ORIGINAL: dlssboyce1
thanks for the info i haven,t found a good repair manuel yet
Oh well - as with everything else - E-bay is helpful here if annoying, fraud ridden and generally unpleasant...
Is a torque wrench that difficult to use or is it too expensive to buy a $80 tool to work on your new $25k+ car? Make sure you get your torque specs right guys it makes for a quality install.
ORIGINAL: 1QuickShortBus
You can get away with "metered hands" on some parts of an iron block, but you are asking for pain on this one - most every bolt you touch has torque ratings that seem loose to me and some times I wonder if the whole thing isn't just glued together with lock-tite
