header thoughts
Old Sep 5, 2006 | 07:07 PM
flewbyu's Avatar
flewbyu
Default header thoughts
I know that some people have trouble with headers leaking, I found this spray that shows leaks with a color change dye. Thought you guys might want to see.
I dont have this problem but some may.
Thanks
Old Sep 5, 2006 | 07:31 PM
cekim's Avatar
cekim
Default RE: header question
ORIGINAL: flewbyu
I have heard that some people have trouble with headers leaking, how would you know if you had this problem? Would you get a check engine light or some other code? Also with leaking is it manly from gaskets not being applied correctly or any number of things?
I dont have this problem but I want to know what to look for if its not obvious.
Options for potential cause:
1. over/undertorque of any of the bolts can warp the metal
2. bad weld (hole)
3. torn/damaged gasket
4. bent flange - (bad manufacture, dropped on the floor, overtorqued, misaligned when fastened)
In any case, you usually hear a "tick" (burst of air) and over time you will see soot (black dust) develop around the hole.
You might also smell it, particularly when the car is cold or idling gas coming out prior to the cats smells (some people get nostalgic when they smell it, some people think it stinks, others just fall asleep and die).
It is _possible_ that you might get a light with a really big leak screwing up O2 readings/temps, but they can leak without messing anything up (either sensors or engine behavior).
Sound was always the first symptom I ran into - but then I did not have injectors clacking away
Old Sep 5, 2006 | 07:42 PM
flewbyu's Avatar
flewbyu
Cekim-- Man you always have some good info! I mean always man. You should be a moderator or something.
Old Sep 6, 2006 | 04:00 AM
cekim's Avatar
cekim
ORIGINAL: flewbyu
Thanks, but I suspect I am too much of a smart *** for that job
Info comes from growing up under a car - father got me started early and I never stopped - now I have twin girls and we spend our weekends in the garage appreciating the stangs and pondering the next wash/wax/upgrade...
Anyway, you mentioned the burst of air sound. How would you hear that with the cai sucking sound? Seems like they would drown each other out and you would just think you were hearing the cai. Well, come to think of it I guess since we are used to the cai sound we should notice a change.
I would diffinately notice the smell I think. Well I guess I will just have to keep my eyes open. Is there a timeline you think to notice? Say within first 2 weeks of install if you are going to have a problem?
Depending on the size of the leak, if you had one, I would suspect that you could see the soot build up after a few weeks - if the car is well tuned and spends most of its time at ideal A/F then it will take longer...
As for hearing the noise - I find driving past concrete barriers on the highway to be a wonderful method for gathering audible info on your car...
Find one, get right next to it with the window open, floor it and enjoy... Under load, if there is a leak of any size, you should hear it.
I would not worry too much about it - particuarly if you had a good shop install your headers, it should be a no-brainer for them to get it right...
Old Sep 6, 2006 | 09:12 AM
flewbyu's Avatar
flewbyu
Wow- I got twins too! I got 4 girls total, Ages are 3, 11(twins) and 12. They would never mess with cars though. They are to prissy acting. lol .
Old Sep 6, 2006 | 11:22 AM
CrazyAl's Avatar
CrazyAl
Reloading your existing tune won't do anything. After all, it's the same tune. I would contact the shop that you got your tuner from, and tell them that you are adding headers. They should be able to supply you with an updated tune file over Email. Download it onto your tuner, and then load that NEW tune into your car. A Dyno tune would be nice (as it always is) but it isn't strictly needed.
Oh, and Cekim is right--your chance of having header leaks is slim. A competent mechanic should be able to install the headers with zero leaks, no problem.
Old Sep 6, 2006 | 11:42 AM
cekim's Avatar
cekim
ORIGINAL: flewbyu
Wow- I got twins too! I got 4 girls total, Ages are 3, 11(twins) and 12. They would never mess with cars though. They are to prissy acting. lol Well, we shall see about any leaks, I get my install 9/7 so the next two weeks I will be looking and listening like crazy! I would have never thought of a leak problems until I saw people mention possibilities on M Forums.
One other thing Cek, I heard that I should reload my tune after the install and that I should be fine, but to squeeze every drop out the new pipes I should get it a dyno tune. Think this sounds solid or is my 93 tune now just fine and no Dyno needed? (optional)
They may grow out of it, but for now, they really enjoy handing me tools and asking me what various parts of the car/engine are for and how they work... Pretty cool...
As for the tune - see Al's response, your existing tune should still be there won't do anything to reload it. As for a new tune, I have not done LTs on this car/engine, so your search is as good as mine, but generally speaking LTs seem to lean things out a little and you can squeeze some more out of them owing to reduced backpressure and temp in the cylinder. So, can't hurt to put it on a dyno, but it is not as urgent as a CAI would be.
Old Sep 6, 2006 | 09:23 PM
flewbyu's Avatar
flewbyu
Ok- Someone else said to reload it but no big deal, I was just checking. I will get a Dyno after the install.
Old Sep 7, 2006 | 08:39 PM
sdwndr's Avatar
sdwndr
I think I am having this problem...When I accelerate somewhat heavily I am getting what sounds like a burst of air. Kind of a SHHHHHH. I don't have aftermarket headers, but I do have an aftermarket axle-back. A leak in that would produce similar symptoms I would think?
Old Sep 7, 2006 | 10:05 PM
cekim's Avatar
cekim
ORIGINAL: sdwndr
Exhaust leaks make pulsed/periodic sounds speeding up and slowing with RPM owing to the pulse form the cylnder.
So, "shhhhh" isn't how I would describe it. More like tck,tck,tck or sh,sh,sh,sh depending on where it is...
Hard to put this in words, but any sustained "whoosh" noise is likely something else (read some auto-trans drivers complaining whooshing noise coming from the trans).
